mammoth questions
MI
mammoth questions
What kind of rims will fit on a Mammoth? Like will t-maxx and savage rims fit
i stripped my 1st an 2nd gears i dont no which gears to get a 65 or 60 tooth gear and if i change the gear and it has more or less teeth will i have to change the clutch bell gears.
MI
RE: mammoth questions
Umm the gears are 65 is the first gear and 60 is second gear....they do make option ones, being a 66 and 61.
The stock Mammoth axles only work on XTM wheels. You can buy adapters to use the standard 14mm hex like the Savage or TMaxx.
MI
Are the stock mammoth rims junk or what? xtmbasher stripped 1 already and the other 3 are on the verge of stripping.. But he still just ordered more stockers and said that they are good.
MI
Nope not junk usually, but you gotta keep them tight and check often.
If you want you can buy the adapters to use the normal 14mm wheels.
