Kyosho Giga Crusher RACER
ON, CANADA
Hi kyoshofans and everybody,
I just got my vacation and i'm planning on building my Kyosho GIGA Cruscher Dual Engine that i bought almost 4 months ago, and it is still in box. But here is the deal: I would like to turn it into a real race machine, I know its limitations, it's heavy and bla bla bla.... but i want to at least try to. Since it will race against REVOs, TMAXX and Savages, I will mount it in the Single Engine Configuration. Can't race a TWIN. I know that it shares a lot of parts from the Inferno MP-7.5 but i'm not sure which ones. So here gpes my questions:
- The shocks are the read or fronts from the inferno ? Which ones should i buy to replace the stock ones ?
- Dog Bones ? I want to use Universal Swing Shafts from the Kanai ? Which ones will fit ?
- Can i eliminate the 3 Speed Gear ?
- Does anyone have seen one in action ? is it stable ? I'm worried about the engine being in the front of the truck ?
- Does the Proline's Powerstroke Shock for the TMAXX will fit ? You TMAXX guys, what is the lenght of the TMAXX shocks ? if any of you own an inferno, compare it with it ?
- I Know the diff is from the inferno, so i will use the Kanai TCD on the front, should i use it on the rear ?
- I'll also use prolines 40 Series Velocity Wheels fitted with Bow-ties.
I know it might sound crazy, but i am a BIG KYOSHO FAN and i don't see myself driving other Truck that's not from Kyosho. I owned a REVO already but it was all problems and i sold it.
Thanks to you all,
Thanks to you all,
RE: Kyosho Giga Crusher RACER
Hey man, I was thinking about doing the same thing. Not because I am a Kyosho fan, just because I hate racing the same truck that everyone else has. last year I had a TNX, and I was the only Tamiya guy out there.
ON, CANADA
Besides being a Kyoshofan I am also like you, I don't like to go with the flow, kind like to do different, try what others might be afraid of.
I'll post pictures as i start to build it.
hey bro i like your idea...i'm also also a kyosho Mt owner "madforce" if you have the pics try to post it. good luck to your plan you can do it...happr holidays!
ON, CANADA
I don't have pictures yet, but i will post them as i build. Thanks all for the encouragement.
I have found out that you can use the Kanai Front Shock Body fitted with the rear shock shaft. It is the exact same length.
You will also need these bearings to replace the plastic and bronze bushings that comes with the kit:
- 4 x 7 x 2.5 mm (02 Two)
- 6 x 10 x 3 mm (04 Four)
See ya.
See ya.
Too bad you can't use the 2 engines.. Even though it won't give you much of a lead over everyone else. I like the GIGA Crusher though pretty unigue !
Hi Guys.
I currently own a Giga Crusher Twin. Very nice truck. Not without a couple of early niggles though.
I previously owned a Mad Force.
Comments on Mad Force:-
Suspension. Yuck. Too bouncy with stock setup and Ultra soft spring set didn't fix that.
Steering linkages. Too many links and too much slop in the linkages.
Handling. Sits on its back wheels too much to try and be a race truck. Severely upset by rough ground. Very easy to control and responsive in midair. You can pick the nose up or shove it down very easily.
Motor and transmission. Love it!!..
Drive line. MUST FIT is the longer joint cups to the front and rear dogbones, otherwise dogbones fall out all the time. You try not to crash a MT on the track.
Comments on Giga Crusher Dual Force:-
Motors. Cool. Lots of power with two running. Easy to start. It would be nice to be able to start them with the body on. Fuel tank access also requires body removal. Could be better.
Exhaust. Those useless rubber stingers. Always breaking or falling off.
Throttle linkages. FU--ING terrible. Too much flex and too sloppy. I have mounted a throttle only servo up next to the carbs. Short straight pushrods. Nice :-)
Handling. Sweet. Suspension works beautifully straight out of the box. Watch the big jumps as it is a HEAVY truck. I have not found that this truck flies well (not really controllable in the air).
I am seriously considering an LST for a race truck. Any comments?
Cheers
Cheers
Here are a few snaps of the throttle servo mount etc.
It was made with a bit of scrap aluminium channel I had lying around, and some K&S square brass tubing as spacers to pick the servo up off the bottom of the channel. This set up requires a "Y" harness to be inserted in the throttle/brake circuit so that both servos operate.
ORIGINAL: kyoshosan
What wheel nuts are you going to use to attach the 40 series Velocity (disc) wheels to your truck. I am having some custom made to do this job. Are there commercially available items? I have the tyres mounted and am just waiting on the nuts to turn up.
ON, CANADA
Hi XR400,
This is a great idea. I just started to build mine and i also found that the throttle servo layout was far from good. Do you know if the linkage are touching the body ? or it stayed below ?
About the wheel nuts, i'm doing the same thing as you. I'll put them on a lathe do cut some of that edge down to fit the 40 series wheels.
Also, Which body are you using ? I'm thinking about the Proline's Crowd Pleaser 2.0
Have you tried the new Proline 23mm Heavy Duty (HD) Hex, yet ? Do you know if they will fit ? let me know.
HAPPY NEW YEAR TO YOU GUYS ALL!!
My Feedback: (9)
Yikes - on my 6th break-in tank, I stripped my 1st gear AND yanked the pull start from one of the motors Luckily, i was able to reinstall the pull start and stole the 2-speed from my Landmax 2 to replace the 46 tooth gear. Hopefully back on the raod today!
ORIGINAL: kyoshosan
Hi XR400,
Hi XR400,
Before you turn down the edges of the standard nuts, check to see that your wheel nut spanner will fit down the 'tunnel' of the 40 series wheels. The biggest spanner I could fit down the 'tunnel' is my glow plug spanner (8mm). Therefore the nuts I am having made have an 8mm (glowplug) hex on the end.
At present I am using a Mad Force body. I didn't want to wreck the original body in case I was going to sell the truck soon. If I keep on using this truck, I will fit one of the following Proline shells:-
F650
F150 Supercrew
F350 Extended
Silverado HD
I won't be using the Crowd Pleazer because is does not look like a "Truck".
No, I have not tried the 23mm hexes as yet. They are not made specifically for Kyosho vehicles. That is probably because Kyosho use 6mm axles and I think all the others use 5mm.
ORIGINAL: marksp
XR400 - I see you changed your air cleaner setup. Did the stock one not work for you?
You guys think a Giga Crusher could spool up enough power to pull my E-maxx (bumper to bumper) on grass. I'm not bashin' or anything, but I figure that it's the only stock rig that could stand a chance against an E-maxx's massive torque. Honest opinion's guys.
ON, CANADA
Not trying to change the subject, but i noticed you own 2 REVOs which one you like best the one with the OS 18 engine or the one with the sirio 23 ? i mean for racing ?
ON, CANADA
I put the tank in the rear to try to balance the truck a little, it has a nose down tendency. I also saw that the original Giga SF has the tank mounted where the second engine was supposed to be.
