GLOW PLUG TROUBLE
GLOW PLUG TROUBLE
Merry Christmas all!
I finally got my T-Maxx! I'm having abit of trouble changing glow plug though? I can't seem to get the blue wire off the plug. I'm pulling really hard but don't want to break it off or damage the wire. I tried pliers and tweezers but no luck? Any tips on how i can get it off.
Thanks alot
BaTTy
Thanks alot
BaTTy
My Feedback: (10)
RE: GLOW PLUG TROUBLE
are you pulling straight up or at an angle? also when you put the pliers to pull, did you put them all the way down were the wire meats the glow plug, if so you might have clamped the wire more. can you take the glow plug off with the wire on it?
NY
ORIGINAL: ScMc
Just rip the wire off and get a glow ignitor!! Much less hassle!
to get it off, pull it off at a 45 degree angle from the plug, and push down. this should pop it off. then unplug the remainder of the wire from the ez starter harness on the shock tower. then zip tie the remaining wires together and keep on truckin.
