Genesis factory (break-in) setting
LA
Hello,
Hope everyone is having a great day.
CEN please reply... I would really like to know the exact factory (aka break-in) needle settings for the .46 Genesis from CEN. Also, when leaning out the engine doesn't that mean screwing the needles clockwise thereby screwing them in? The idle mixture screw is on the side away from the fuel line and the high speed mixture screw is on the same side as the fuel line? So if I screw in the needle opposite the fuel line I'm setting the idle mixture more lean???
AMajor
AMajor
LA
RE: Genesis factory (break-in) setting
Never mind. I got the information I needed from a CEN authorized dealer today! [:-] For anyone reading the break-in setting is to have the low speed needle (opposite the fuel inlet line) flush to the housing and the fast needle (same side as the fuel inlet line) about three and a half or four turns. But the high speed mixture shouldn't matter if you are idling now should it???
