MGT Help!
TX
MGT Help!
I received a monster gt for Christmas and after break in, while tuning the engine, I noticed that one of my rear wheels was loose. After closer inspection, it seems that the wheel hex has totally stripped the center of the wheel out. I have bought new wheels and tires and put them on, only to find out that the same rear wheel is pointing inward toward the truck. I have looked over everything, adjusted the turnbuckle and the truck looks fine while sitting on a flat surface, but when you pick it up, the tire is almost at a 20 to 30 degree angle. All of my other tires are fine. I do not want to run the truck because this is probably what caused the wheel hex to do this in the first place. Any help would be greatly appreciated.
My Feedback: (10)
RE: MGT Help!
actualy you need to check a few things,
1, make sure that both bearings are in the hub careir
2, adjust your chamber, (anyone with an mgt could you tell them how its done, i dont have an mgt, so no info is known how to)
