Fuel Filter on a Mad Force
MI
Ok. Where the heck do I mount this thing? Any suggestions? It doesn't have any mounting piece, and I'm trying not to resort to drilling holes in the side plates just yet...
It seems every where I try to use existing holes, it butts up against the pipe or gets dangerously close to the clutch bell.
My Feedback: (20)
PA
RE: Fuel Filter on a Mad Force
Not knowing what your up against,(cant picture the truck) but I would suggest making some sort of extension bracket to go above the exhuast, or which ever position looks more :"safe". Something like an "L" bracket, you would use to sure up corners in woodwork.
MI
Yea, but I have the stock pipe. So that's right were I have the exhaust system. I may run mount it on the other side, if I can make safe clearance for the throttle linkages.
