How are the PICCO or FANTOM Big Blocks?
How are the PICCO or FANTOM .27? I was looking at getting one of the two, but never seen them.. I know the Picco .27 isnt out yet(i think).. and I heard the Fantom .27 is a screamer... I race my MGT, so i need a reliable track runner ..
RE: How are the PICCO or FANTOM Big Blocks?
Not sure about the .27's.
I have several 24.7 Pro's, and an Ofna Picco .26 though, and I can tell you that the Picco .26 is stronger than the 24.7 Pro. Both are outstanding motors, and easy to tune.
I also have a Orion Wasp .28 and a SH .28. And the SH motor is considerably stronger. The wasp is harder to tune, while the SH tunes easily like a 24.7 Pro.
How do you like that 24.7 Pro in your MGT? (mine are in the Savage and Mammoth).
Both engines are known not to be a pain in the bud to tune and they would lose the tune fast, so I wouldnt buy one of those.
what about the SH .28 ? more power, and easy to tune and reliabel.
NJ
i use the first generation fantom .27. it feels like it revs noticeably higher than my picco 26. i've never tried to remove the carb after thermalrd posted about how tight it was. he said that his wrestling it off resulted in metal shavings in the crankcase. the pullstart spring took a crap on me after about 1.5 gallons. i'd say it's a great racing engine, but i'd try an sh 28 before i buy a 2nd generation fantom. I'm not even sure what the difference is between the '04 and '05 fantom, but I do know that the sh is cheaper and proven to be reliable. I'm not an expert on tuning, but i've never experienced the on again/off again power problem that many have had trouble with. hope this helps.
These 2 are very close. I have run both for a while now. The SH is stronger but the Fantom is very very close to it. It's a smooth power band on the .27. The picco .26 is a good engine and should be a good buy right now all the problems with the first runs are over and it can be had cheap. AS far as which is best there is none depends on the application.
BC, CANADA
Anyone with real model engine knowledge will tell you the picco26 is no good for racing IT IS A LIGHTSWITCH!!!!!
VA
My 27 slightly (very slightly) out-revs my SH28, but the SH kills it through the powerband, ESPECIALLY on the bottom. You say that your 27 is very very close to your SH. Mine REALLY is not. The 27 does have a nice, wide powerband and revs high but to my style of driving the two are night and day different. From a standstill my SH will put my Savage on it's lid with 18/49 gearing (top-end gearing for you non-Savage guys)... I can't get that kind of take off with a 16tooth CB on my .27.... I never had any big issues with my 27 though, and it only saw about 3 gallons. I have engines piling up on me...
ORIGINAL: Frost_
VA
ORIGINAL: bcash
Yea frost close. Very close. Thats why setup is so important and so on. Cause 18/49 with the Sh on my savage with Vertigo chassis will not wheelie for me right now. But it lays good power down. I have had the savage a while now but got this in a trade so I'm new to it. But I do know short wheelbase savage's will flip over with damn near anything. Is your's short wheelbase? I'm really curious about the 18/49 in a savage I did alot of reading on it on savage central and saw all those vids. It may be the tires I'm running thou the proline 40's road rage on the 23mm. Now did you run the 27 in the savage? And yes your right the SH has the grunt down low. But I like the smoothness of the .27. Whats faster then what is a very hard discussion to have. I think it's setup more then anything.
ORIGINAL: Frost_
I definately like the Ofna Picco Outlaw .26 that I just put in my Ultra, though the .26 is now being replaced by Picco with the .27... anyways I got it NIB for such a good price I could not pass it up.
My buggy is quite quick and it holds a tune rather well I thought.
