TNX Glow Plug
RE: TNX Glow Plug
Hi repete,
Thanks for the reply. The car is 20%-35% nitro - would a hot plug seem appropriate? Also the T3 is called a "Standard" plug which might mean it's a medium heat plug.
Jon
Jon
NY
RE: TNX Glow Plug
I have always had good luck with the OS #8 plug! Most small block engines run better with a medium to hot heat range plug. BB's will use a cooler plug!
