Novarosii 528xrp
BC, CANADA
RE: Novarosii 528xrp
THe rossi 28 3 port has bout the same power as the sh 28 The lst can handel it! I would use alloy diff cases to stop flex.mabey ti cb n spurs.o ya and a wheelie bar!!
BC, CANADA
I used the 3 port as an xtream example cause it has more bottom end torque than the turbo 8 port, the 8 port has more top end!
ORIGINAL: korevo
thank you bro! But mine is 8 port not 3 port it's a race engine .28 will order ti geras n diff case alu
Have a hard time starting my novarossi 528X Race Engine so converted it to roto start of nova the problem is have to start it sideways with roto start located facing bottom do this affect my hard starting of my LST
Im thinking of putting the same engine in my Kanai3 Truggy. But the one modded from EBMODS.com.
http://www.ebmods.com/pages/engines/...8_modified.htm
How do you like it? Hows low/top end? Does it drink gas alot????
