MGT race setup?
KY
MGT race setup?
What are you guys doing to your MGT's for racing. I have not even fired mine yet I know that I am going to put the forward only unit in it and that I am going to put the side exaust kit on it. Our track is a hard packed surface that is kind of dusty too. What do you guys reccomend as far as tires wheels and diff fluids for this type of track. thanks guys
MA
RE: MGT race setup?
I just ran almost Gallon this weekend all stock except 40series dish/bowties by pro-line
These help in the corners! MGT needs a good set of treads I bent a rim so I would look into
a stronger rims for the 40 series or change to the 23mm hex, If you run a long track change gearing
for more top speed. And get the better steering kit I was told it gives it better turning radius!
Other than that I was out in front most of the time with slower motor!
And I'm getting side mounted tuned pipe!
Go to http://www.hobbieguyrc.com/assoc_monster_gt.htm
Have Fun!!!
Have Fun!!!
IN
RE: MGT race setup?
Try saxtons set up.. this will give you a nice baseline http://teamassociated.com/racerhub/s...chal.2004s.pdf
BC, CANADA
RE: MGT race setup?
The main thing i did to my mgt to make it way more race worthy was sold it and bought a LS j/k shed weight any way you can! get it as low as you can! forward only trans! It's designed as a monster so your kinda limited if you wana make a full blown racing machine!
KY
RE: MGT race setup?
which wheels and tires do I need I looked on tower and it is a little confusing as to which ones will fit the mgt. Do I need the proline hex adapters to run then ( dish wheels and bowties)
IN
RE: MGT race setup?
hey james, come over to www.monster****rum.com we have alot of info your looking for..
IN
RE: MGT race setup?
Here is another web site that one of the members from www.monster****rum.com designed http://www.members.cox.net/dbfraser2/mgt/home.htm
KY
RE: MGT race setup?
ok guys so the proline dish wheels that are for the tmax that are off set provide more steering , did I read that right and the proline t
max bowties correct. This is where I was confused either the offset or the non offset
