ofna monster pirate diffs
KY
I have a question guys. I am helping a friend rebuild a used monster pirate and the gears in the rear diff were stripped. It was packed with black grease. It is the older planetary type. We orded all the new gears and my questions are do I refill them with black grease or can I use a heavy type of silcone fluid for them thanks
BC, CANADA
RE: ofna monster pirate diffs
If its has the plastic case's switch to alloy(dominator)one's or they will flex n strip all the time! and only grease in those one's silicone will leak! shim your ring n pinion gear! www.ofna.com dom/pirate forum all the info you will need!
