mach .26 important question?
how do i get the clutch bell to fit the mach .26 from the stock .21?
i kinda need to know by tonight if possible.
ps. this is for a mgt.
thkzz
thkzz
RE: mach .26 important question?
this sucks its got the wrong crank in it and it costs me 55$ to put the right one in! damm
is there any way i can make it work without spending 55$?
or should i just try to sell it "its brand new"?
will the crank out of the stock engine fit?
any ideas?
any ideas?
WA
i doubt it has the wrong crank in it, but im sure you will have to swap out the flywheel from the stock 21 on to the mach 26 then fit the 21 clutchbell to it
VA
-EDIT-
Oh, you got this one: http://h1071118.hobbyshopnow.com/pro...p?prod=DYN0885
but you need this one: http://www.horizonhobby.com/Shop/ByC...ProdID=DYN0887
WA
what does the end of it look like? and where did you get the mach 26? if you bought it from a hobby store and its still new maybe you could trade it for the one you need
BC, CANADA
He bought the one that's made for da t maxx conversion dynamite 26 threaded shaft! and needs the sg crank!! sell it!! or take it back!
ORIGINAL: 2strokefreak
thkzz
thkzz
http://www2.towerhobbies.com/cgi-bin...?&I=LXABA2&P=0
i was thinking the same thing, except i was gonna try these
http://www2.towerhobbies.com/cgi-bin...?&I=LXBCK5&P=7
http://www2.towerhobbies.com/cgi-bin...?&I=LXBMD5&P=7
does anyone know for sure if this will work, im buying alot of shims to?
