mammy st
RE: mammy st
i ws considering buying one yesterday, but when i got the my lhs the guy said that he sold the only two he had within about an hour of receiving them and when he reordered they were already back ordered..............so looks like i'll have to wait[]
My Feedback: (8)
MI
RE: mammy st
I have had mine since the 4th and I love it so far. I have even ordered another. I think it is a great deal. The stock motor runs great. Handling is just like a buggy. I put a M8/Spektum and digital servos in it right away. I had a issue with the servos but Global jumped right on it and got with me. I am impressed with their service.
TN
RE: mammy st
ORIGINAL: sjm
My Feedback: (8)
MI
RE: mammy st
The engine has been excellent so far and very easy to tune. Great acceleration, ST is only 10lb. Yes very good top end with the 2 speed center. Yes it is 4WD. This is by far the best deal out there at $339. In my opinion it would still be great at $100 more.
RE: mammy st
its not a stadium truck.............its a purpose built racing monster truck.............or truggie if you will. the st does stand for stadium, but it refers to it being the "racing" version of the mammoth.
RE: mammy st
ORIGINAL: sjm
My Feedback: (10)
RE: mammy st
you can prolly get a realy cheap deal at tower
339.99 for mammy st http://www2.towerhobbies.com/cgi-bin...&I=LXKYZ7&P=ML
- 30 off 011LE
total: 309.99
chris
- 30 off 011LE
total: 309.99
chris
RE: mammy st
ORIGINAL: s maxx
stock steering servo is sh*t i put a 645mg and a 6v pack awesome now on my 10 tank nothing wrong and have the same glow plug in it
RE: mammy st
I would defo put the ring in or you might be putting too much stress on the engine.
Lean it right out til it goes as fast as it can then richen 1/8th of a turn.... lean = mean!
YT, BOTSWANA
RE: mammy st
You could definitely lean out that engine. At tank 6 i typically look for my performance tune. Now, with that engine i would say to use the head shim for 30%. Although i KNOW its not necessary, it is recommended. I have been running my XTM 24.7 Pro from day one with 30%, and no extra shim.
ORIGINAL: aluminum crusher
Hey folks i have been running my mammoth st breaking it in acordding to the instructions leaning it in a 1/8th of a turn after each tank with ten minutes of cool down in between tanks. Yeah Big Baby this thing is fast but it is still running rich on tank six, my high speed needle is at 2 1/2 turns & low 2 1/8th turns out. IT is running very rich shall i continue to run at these settings or shall i lean the low end screw some more??? I know the answer to this question that i ask but would like to here from you guy's. Because my answer might be wrong. I'm running 20% trinity fuel for the moment, the steering servo SUCKS almost 200 oz of torque my foot it's more like almost 20 oz of torque. Other than that so far so good, would like to go to 30% nitro next but i don't have the 10mm head ring as the instructions suggest to use when running 30%. Do i really need this ring. Thanks for your reply's
ORIGINAL: s maxx
RE: mammy st
HI folks I put in the 30% with no x-tra head shim and boy the POWER is there. The highest temp i got it to so far was 211 degrees but it is still running rich, taking off slugglish ( for my taste) but i will get the bugs out. I guess my type of breakin process has been going slow. I tighten up that servo saver tension ring and LOL @#@#&**&*&+_($#@#^&^) before i got to try it out with the tension ring all the way up the freakin pull starter broke it will not recoil . It sounds like the pullstarter spring is broke or came out of it's slot I will take it apart friday and see whats going. I'm already tick off I got 3minutes of fun for 339.00.(break in time don't count as fun) I hope the hobbystores has a pullstarter in stock or it will be for sell,and i might go back to 1/5th scale or just leave this frustrating hobby alone.[sm=disappointed.gif]
RE: mammy st
its .1 mm not 10 mm! the sterring servo says 200 oz i not person has said thats true more like 40 oz. to aluimnum crusher if you can afford it starter box and the pull start as back up good luck
RE: mammy st
ORIGINAL: guest2001619
