How to remove my LST carb?
Hey guys I was just wondering how to get the carb off of my LST? I took the nut and washer off that was connecting it to the engine but I can't get the screw back through to finish taking it off?
GA
RE: How to remove my LST carb?
You cannot take the screw/bolt out untill you pull the carb off. Once you've got the nut off just grab the carb and pull straight up with maybe a little twisting motion. Once the carbs off, you can pull the bolt out.
When you put it back togeather, be sure to install the bolt first and put a little "sensor safe" rtv sealer on the throat of the carb or you could easily get an air leak. Not a lot though, you don't want to gum up the inside of the motor.
Dave
Dave
