Rebuilding a motor?
Banned
My Feedback: (7)
TX
Rebuilding a motor?
its a .12 picco rc speed motor, i bought a new piston and sleeve for it and i need to know if i have to replace the connecting rod too, the rod looks fine, i just want some people to tell me what theyve done and how it worked out
My Feedback: (8)
MI
RE: Rebuilding a motor?
if you havent abused the engine then the con rod should be ok to reuse.
I have replaced the piston and sleeve without replacing the con rod in my ofna force .25 and it ran strong and long like a new engine.
as long as you break the engine in correctly and dont overheat it\run it to lean, then the con rod should last for multiple rebuilds.
