CEN GENESIS TOP END SPEED PROBLEM
Hi my problem is that i put on 23mm 40 series wheels onto my genesis but it seems to have lost all its top end speed, it can only reach about 20mph now is because of the wheels or that its not going into 3rd gear?
RE: CEN GENESIS TOP END SPEED PROBLEM
With the smaller tire your top speed will drop and your truck will shift gears much sooner because the RPM's go up faster. I tried smaller diameter street tires on my CEN MT2 and did not like it. It also caused my motor to overheat because it was running at higher RPM's than it normally would
The CEN is certainly not known for its top end speed in the first place. I was going to put the CEN motors on my Giga Crusher but I found out through research that the motors would kill my top end. I would suggest either change the motors at great expence, or put the original tyres and wheels back on.
cengenguy,
To get your Genesis back in order use the new tires / wheels
which CEN has for sale.You can have alook at them on there
website under newproducts.
The wheels are too small - they effect your gear ratio. If it is not shifting into third gear it is because the truck is not going fast enough.
oh yeah.... What made you put those wheels on?
What are you playing at putting those tiny wheels on the cen? the cen has some of the biggest wheels going, those are smaller then the stock lst wheels! of course it has killed your top end. The highest speed gear is now probably barely the same ratio as the lowest gear on the original wheels, just put the stock ones back, on can't see what is so hard to figure out?
