Running in wet conditions???
Howdy, what do I need to do in order to run in the rain, snow, mud, etc.? I've heard of ballooning but I dont know how to do it and plasti-dip but can anyone give the instructions on how to do it??? Thx
RE: Running in wet conditions???
basically it's just your receiver and cells that needs protection
Wire your receiver as normal, then get a big balloon and put your wired up receiver inside, then tiewrap the neck of the balloon (I liked to pack the neck with a sponge first) to keep 99.9% of the water out
Servos usually have 'o'ring seals but you can belt & braces with silicon sealant
Cells can be a problem, so maybe find a plastic box
Electric motors can run happily underwater (at reduced brush life - not so sure about brushless tho') but watch for grit acting as grinding paste
Kev
Kev
PA
Here is a website on how to waterproof a nitro rc.
[link=http://www.misbehavin-rc.com/pit-lane/waterproofing/gn-waterproofing.asp]Waterproofing[/link]
My Feedback: (34)
IN
Alot depends on what you have. I've run my Savage in pouring down rain, plowed through deep puddles with no waterproofing at all and the radio case was dry.
Two things to remember, the wheel bearings will need to be cleaned/regreased and your slipper may become glazed afterward.
Also, your tires will fill with water (if your bashing in water/rain). It's best to have a spare set with holes cut into them, otherwise your foams may rot.
