LST Drivetrain+Tranny
RE: LST Drivetrain+Tranny
I have the LST and have had no problems with the tranny or diffs, but you MUST upgrade to the aluminum diff cases. Now the CVDs are a different story, I have broken MANY CVD pins, broke one in the last race, I had about a 1 lap lead in the B-Main when I broke the right front CVD pin, then I had to slow my pace as this thing is a doughnut machine without front wheel drive, ended up finishing 4th If you can find a way not to break the CVD pins then the drive train is rock solid.
TX
Stock the LST has a all metal drive train except for the spurs. Anyone who tries to tell you plastic will hold up.. (in the tranny) be very wary of...
In over a year I have never broken a CVD pin. I used to break the hex pins but after cutting some out of 3/32 piano wire I have not broken them in about 18 gallons.
[link=http://www.dennisnadams.com/tmaxx/LST/Collari32_HeatCycle_3.wmv]Video: Abusing drivetrain with Collari .32[/link]
[link=http://www.dennisnadams.com/tmaxx/LST/racer_04212005.wmv]Video: Abusing drive-train with stock Mach with Sportwerks carb with 9mm insert[/link]
Creating a lifetime supply of hex pins for about 3bux......(I've never broken one of these)
SkyOdessy: Is this your first metal CVD's?? Are you sure you are not over tightening them??
TX
Replace the diff covers with the Alum, LST2 comes with alum diff covers. The LST has a all metal drive train with 6 CVD's. It has handled every engine I have put to it.
2DMaxx, are you using upgraded CVD pins? After breaking the first 8 or so I started to make sure that I only tightened the screw until it felt snug. I have fell out\off pace of SO MANY races because of this. This happened the last three mains, 4 out of 9 qualifiers, and MANY more times during practice. Only broke the actual shaft 1 time. I have tried leaving them so loose that the pin actually starts to fall out. So I assume that the weight of the truck is too much. Happens mostly in the front, only twice in the rear. I almost want to not qualify just so I know the pins are good for the main.
ORIGINAL: camtheman000
I've heard alot about the madcat a-arms. are they any good?
TX
I use the stock CVD pins and have never lost one during a race, heck never lost one ever for that matter. I hear other people talk about this but I've just never had a problem with them in 17 races days.
TX
MADMAC A-arms are great but I'm not sure if he is still making them...
ORIGINAL: 2DMaxLST!!
On a side note, I have never broked a hex pin like you have. Go figure[&:] I wonder if that piano wire would be stronger that the CVD pins?
TX
You know, if I was having your problems, I would get the wire and the dremel out and go to town. I would even dremel a flat spot for the grub to seat in and use some red locktite and firm them down, then wait at least 12hrs before using them. There's a lot of things that can knock you out of a race but it should never be your CVD pins....
I've raced on tracks from Houston to Phoenix and my local track is the hardest. It's not watered during race days. It is prepped with water and a roller and then baked in the 100+ heat, it develops blue groove by the third qual... very tough stuff, brutal tough.
TX
I'm 99% sure it is 3/32. When you go to pic it up at the LHS just bring one of you axles with you and see what fits in the CVD cups. I am curious to see if this takes care of your problem!
CA
Do any of you guys know how to create a poll?
CA
ORIGINAL: skyodyssey
I had Thermal look at my truck and he think that the pins are falling out and getting broke when they hit the axle carrier. So I am going to use red locktite, shrink tubing, and CVD boots. I am confident that this will solve my problem. It wasn't that I was over tightening them, it was that even with blue locktite the sqrew will back out and the pin starts to fall out.
2DMaxx, your track looks awsome! Man would I love to race a track that size! What are common lap times at that track?
That would be awsome....maybe I'll take a trip to texas I think good lap time at our track is 18-20 second, but I am usually around 24-28 seconds because I still suck.
CA
Well... I was using blue thread lock also, by mistake. I think this is the culprit!
LA
Wow, more people having problems with LST's........whooda thunk it? Just joking , kinda. Nice track!!!! San antonio rocks!!!, I was there a couple years ago for my Bro's wedding. We ate at this place like taco bell, but you could get drunk there too!!! Taco Cabana I think!!! Great place....and again.....nice track.
ORIGINAL: DodamissC
