long term affects of running too rich?
PA
RE: long term affects of running too rich?
You will ruin the connecting rod if it's too rich, if the top of the cylinder never expands the connecting rod gets alot of un-needed stress usually makes the bushing to the crank egg shaped or plain sloppy.
My Feedback: (-1)
running the engine too rich is said to be worse than running it too lean. A little richer than perfect is best for normal use, so the engine lasts longer
Running the engine rich will have no negative effect..........if the temp of the engine is high enuff to allow the sleeve to expand and not cause the piston to drag. In fact, except for the fact that performance would be way down, engine life would most likely be longer.
On a new engine, running very rich and not allowing it to come up to temp does put a lot of stress on the rod, it also causes a lot of wear to the top of the piston and sleeve as they scrub together.
As far as the one way slipping, a lean setting using 18% oil might be putting more oil in the crankcase than a rich setting with 12%.
Ed M.
Ed M.
Your glow plug wont last as long, and the engine will become encrusted with carbon deposits. These are usually easy enough to fix but just something to think about.
MI
Actually too rich is a huge problem.
Compression is higher when rich, meaning alot more wear on the conrod and its bearings.
Also tell me why over rich increases engine temps bentgear...it matters very much to be able to tune correctly...
Too rich is really hard on an engine, more so than you might think.
Ed M.
ORIGINAL: binaryterror
But this does raise the interesting topic of "fuel rich or oil rich". By running with too much oil, you are actually running with a lean condition. Oil is not combustable, so the more oil that's in the fuel means a higher air to (combustable) fuel ratio. It is entirely possible to burn up an engine by having too high of an oil content.
But since r/c fuel is pre-blended, most people will never experience that problem.
AB, CANADA
I've been into 2 stroke dirt bikes for quite a while now and I am in my second year of petroleum engineering tech. and I can tell you that the older bike engines are very similar to the RC nitro engines. Lloydy has it right. It takes a certain amount of air to burn a certain amount of fuel. If you add more fuel it takes more air, simple right? if you get too much fuel into your cyllinder (AKA running too rich) it takes more air to burn that fuel than can fit in the cyllinder during one stroke. This causes incomplete combustion which results in less power, less mileage/runtimes, and also deposits from the un-combusted/semi-combusted hydrocarbons can build up and cause wear on the piston/sleeve. On a bike or even a diesel truck you can tell when this has happened because the engine will start "knocking", especially when cold, before the piston has expanded. It is probabaly impossible to tell when a nitro RC is knocking being that they are so small and loud.
IMO the best way to run an engine for anything other than racing, is to tune it perfectly and then richen it just a LITTLE bit to improve engine longevity. If racing, tune it a bit too lean. running lean though will reduce engine longevity because of lack of lubrication, internal temperature, and running lean makes each combustion more powerful so eventually your piston top can get worn badly. I've seen some bikes that were tuned so lean a hole was made right through the top of the piston.[X(]
MI
Yup, I meant that too rich adds both fuel AND oil into the same size cylinder and now the same parts have higher forces against them...
