Swamp kong tires
KY
Swamp kong tires
Hi,
I'd like to get some SWAMP KONG tires.But they are 8.5 inches tall.My curret tires are only 5.5 inches tall how much will these slow me down I can top about 40 mph now.
RE: Swamp kong tires
You'll gain about 54%, or 21mph at the same motor rpm, according to the calculator. If the motor has enough power, you should top out faster, but it will accelerate less quickly.
he is right techinicly you should go faster but i think if anything you wont gain anyspeed ifnot loose some. heretique is right with the calc. but i think he may have forgot the weight factor. these are one piston glow engines that crank out more hp then torque. first off wat truck do you have, wat engine, and do you have ANY aluminum parts.
also larger tires puts more strain on the drivetrain and servos.
KY
I have a .15cx that puts out .85 horsepower at 28,000 rpms.I don't know how much torque it has .I have no aluminum parts.I'm thinking about getting a OS .18 that makes 1.3 hp at 28,000 rpms.And when I get that I may get some aluminum skidplates.
Hope that helps.
Hope that helps.
ok well considering that os serverly underrates there engines ur .15 probably pushes 1.5 hp and that .18 is wayy more like 2.5 hp. but i wouldnt get the big tires until you get the .18! just because you probably would get fast if you had the .18 and bigger tires.
the reason i asked if you have aluminum is cause thats even more weight than stock and if you truck was already having trouble pushing that aluminum around then it wont take the tires at all.
so yea i would RECOMEND that you wait till the .18 but its ur truck.
You can also change the gearing to reflect the stock relationship between the final drive ratio and the tires.
I too think that everyone is correct about the torque. Go for the larger motor and then try out the big tires.
ORIGINAL: ZoomZoom1
Hope that helps.
Hope that helps.
KY
Holy cow!!!!
Thats A lot of torque!!!!! Do you think that might be so much that it would break my drive shafts?
Also how fast do you think I'd go with the OS and tires??
I think you'll gain some speed, but there are too many conditions to figure a real number. Others pointed out the weight factor, and I also think that's going to limit the increase in speed.
I don't know about breaking axles or anything, as the relationship between parts and motors is not really my field of expertise. It is more than twice as much torque as calculated (if I'm correct), and I'm ot sure of other problems which you might experience.
i would say dont buy the tires and go to www.towerhobbies.com
then first search pro-line 40, then pic the wheels you like from there
then second search for pro-line moab, get these they are good bashing tires
then search O.S. .18 TM
you will be set
you will be set
KY
I found some tires that are 6.25 inches tall. like I said my current tires are 5.5 would Should I get a bigger motor with these too???
Thanks again
Thanks again
That's not much of a difference, my tires are the same, 6.25". They are cheaper, too. It's really up to you which tires will make your truck perform how you'd like.
KY
I realy like the way it peforms now.I just want it to look cool to tell you the truth.
Will the .75 of an inch make a differnce in the performence??
Well, that does translate out to more than a 2.25" increase in the tire's circumference, so all things being equal, it will yield a higher top speed. They are heavier by a bit, and will take more power to attain that higher speed, so it's hard to tell exactly what will take place. It may end up not being that much of a difference.
If you really want the look of the bigger tires, I'd go for it. But that's just me.
KY
Okay,
I can't make up my mind if I want to get new tires the same size or Jubos.
I think I'm tilling torwed the jumbo side right now. Do you know or any tires that I'd like ???
Jumbomaxx tires are massive, I have the jumbo chevrons and they certainly put a lot of stress on the drivetrain. I think all of proline's 40 series (including moabs) are lighter, so if you want huge tires and also speed, go with proline.
KY
I just looked and You could buy a set of swamp kong tires for $84.95
Pro line tires rims add up to $110.00 pluss the price of adapters.
I'm starting to fill dizzy.
KY
I like the proline tires.but it would cost me $154.97 to get proline tires,rims,and adatpers.
thats a lot I know but, now their saying I'll need a wrench from Great planes to install them.
Do I???
To get the Swamp Kong tires it would cost about $94.00.but, I think that would put to much strain on my drive train.
To get the Jumbo Maxx tires and rims it would cost $97.00.Do you think that would be to
much strain on my drive train???
Thanks Again!!!
Do I???
Thanks Again!!!
TX
I may be wrong but you're probably going to loose some steering response with those huge tires as well, I don't know what kind of truck you have or what kind of steering servo but for tires that big I would think you need a pretty heafty steering servo or dual servos to get the same turning response.
KY
I don't have any of the dual servos or anything.I don't know if you'v seen the jumbo maxx tires or not. If not, they are 6.25 inches tall.My current tires are only 5.25 {or 5.5 depending on the ruler} inches tall.It steers just fine now. When the batterys are brand new it takes it 1 secoud to get from all the way left to all the way right.Timed it myself .Would that make that big of a difference??I am planing to get an O.S. .18. so they should not slow it down to much.
Yeah, I didn't even think about the steering much. With the larger tires, you'll need some extra torque to move them, but it shouldn't make much difference while your truck is in motion. Sitting still, it will be hard to turn them for sure. That probably goes for the 6.25" tires too.
ORIGINAL: ZoomZoom1
KY
NOOOOOOO sir no racing.
I just like zipping around in my yard.So you don't think that they will do any harm.
PS I have an old .15 t maxx.
