My LST2 will be here Monday!
AL
Finally got my LST2 shipment verified. It will be here Monday 02/27/06. I know I need loctite for the grub screws; are you guys using blue or red loctite for this? I know blue releases easier if I need to remove them later, but will it hold good enough? Also, which break-in procedure should I use for the Mach 427? The manual recommends idleing or driving in a slow oval for a couple of tanks, but I've heard "heat cycling" may be a better method. Any suggestions?
TX
RE: My LST2 will be here Monday!
I use locktite paste in stick form, blue and never loose grubs or wheel nuts. You can purchase it at a local autoparts store. IMO there's no where on the LST where Red is needed. I prefer to heat cycle my engines. lstcentral.com is a good site for LST info and congrats!!
