Warhead, direct radio replacement.
IN
Does anyone know what radio can directly replace the radio in the Warhead, I mean which one can you just switch the receiver and radio and not the servos, the servos plug right into the new receiver? If money was no object, what would be the best and require no effort in servo change out? If this was answered before, sorry. I searched for something on this but could not find a good answer.
Thanks.
Thanks.
MI
RE: Warhead, direct radio replacement.
not sure what servos the Warhead has, but you can use any radio/receiver with it. If there is a little tab on the servo leads, just carefully trim it off. Its only purpose it to align the plug and prevent backwards installation. Otherwise every servo runs off 3 of the same wires.
If you like to bash or race with more than a couple of people, go with the Spektrum radio. If money is no object, go with the Nomadio.
