Monster GT 4.60
Location: Bakersfield CA now watford UK, UNITED KINGDOM
Monster GT 4.60
Hi all I just bought a Monster Gt 4.60 on ebay because of all the good reviews I heard about it and was wondering is there anything I should know about it like upgrades to do first or parts I should stock up on if you want to check it out its item #6046292793 thanks for any information you can give me.
RE: Monster GT 4.60
Make sure to check all the driveline's. You should thread lock all the screws so they dont fall out. mine is all stock and is great. for now
FL
RE: Monster GT 4.60
If your using the stock radio, be careful of the 3rd channel button. It's very easy to hit by accident and that could damage the gears in the trans.
RE: Monster GT 4.60
Also does anyone think this would be a good kit http://modelsinmotion.co.uk/product....de=&tamiya=268 thanks.
1 Post
RE: Monster GT 4.60
ORIGINAL: Bria1
Just try it!
IN
RE: Monster GT 4.60
ORIGINAL: guy4x4
AZ
RE: Monster GT 4.60
ORIGINAL: snowbl!nd
There is actually a clutch type safety mechanism thing in the tranny to prevent it from switching from fwd/rev when the truck is moving. If it's working correctly you can't do any damage!
Just try it!
ORIGINAL: Bria1
Just try it!
1 Post
RE: Monster GT 4.60
Well i wasn't suggesting you try it when the truck was at full throttle lol! Even at low speeds it'll stop you damaging the tranny - there must be almost no movement in the transmission before it will allow it to shift from fwd/rev.
FL
RE: Monster GT 4.60
I don't have to worry about it. I got a FOC in mine, but I've heard of this happening when jumping. Then when you land and get on the throttle it is in reverse.
ORIGINAL: snowbl!nd
Just try it!
ORIGINAL: Bria1
Just try it!
RE: Monster GT 4.60
Once i was driving mine and hit the 3rd channel, i was like shoot, but nothing happened,i was going like 5-10 mph, when i stopped, it went into reverse then. So it must work
1 Post
RE: Monster GT 4.60
This is a great site with a lot of info on the MGT - well worth checking out. [sm=thumbup.gif]
http://monster****rum.com/articles/
RE: Monster GT 4.60
My truck should arrive tomarrow what that best way to start it with a drill or the pull start thanks.
RE: Monster GT 4.60
Ok thanks because the dude I got it from said he took the spring out of the pull start or took the pull start off because it was in the way
RE: Monster GT 4.60
I have never started it with the drill start. I probably should because i do not want to break the string, or the one way. They are expensive, and i heard they are hard to take apart.[]
1 Post
RE: Monster GT 4.60
No, they're not that hard to take apart. I pulled the string all the way out of the pullstart once (knot slipped on the other end) and i fixed it in about 15 minutes.
For break-in i reccomend you use the pullstart, that way you shouldn't damage it if it hydrolocks. After it's broken in then either method works well.
RE: Monster GT 4.60
I broke mine in with the drill and after I got tire of forgetting to recharge it, I use the pull start besides its just something else to carry around . I left it fully stock only because I havent used it much since Ive basically broke her in and then the winter came so shes been in hybernation with less than a half gallon run through the engine. I will say its a great truck I have the .21 version like 2 months b4 the upgraded model came out [:@]
RE: Monster GT 4.60
Well my MGT came today but it only has the .21 engine how hard is it upgrade to the newer engine or a diffrent company bigger engine would it be a direct fit thanks.
1 Post
RE: Monster GT 4.60
ORIGINAL: guy4x4
RE: Monster GT 4.60
Ok on the new MGT 4.60 it says all metal gears what gears would I have to change on my .21 MGT to have all metal thanks.
