RC Monster Trucks Discuss rc monster trucks in this forum
Ungluing Tires?
Reply
Old 04-10-2006, 05:46 PM
IamMonsterMan
IamMonsterMan's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Ungluing Tires?
What is an easy way to unglue a tire from rim? I just got some new wheels and want to keep the tires
IamMonsterMan is offline
Old 04-10-2006, 07:38 PM
whitesox350z
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Ungluing Tires?
boil them or put them in the oven
whitesox350z is offline
Old 04-10-2006, 07:47 PM
mikewoodkozar
mikewoodkozar's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
First cut most of the tire off that you can with scissors (dont cut the foams, ouy might be able to use them again!), then soak them in acetone (works very well) then when your wheels come out they are super duper clean!
mikewoodkozar is offline
Old 04-11-2006, 08:01 PM
Joe Ortiz
My Feedback: (75)
Joe Ortiz's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I think he wants to keep the tires.
Joe Ortiz is offline
Old 04-11-2006, 09:18 PM
DaveG55
DaveG55's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have tried boiling and baking and never had any success. I've heard that acetone will work but I've never had much luck with that either. I've quit trying and just get new tires too and keep the old set for spares or when I just don't want to screw up a new set.
DaveG55 is offline
Old 04-11-2006, 10:06 PM
lax195
lax195's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Has anyone used paint thinner? I think paint thinner would work better than acetone.
lax195 is offline
Old 04-11-2006, 11:27 PM
BayMan
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Paint thinner is TOO strong is will eat away at the tires rendering them usless. Have you tried heating them up then prying them off(with a good amount of force)? Thats what i do and I resuse my tires.
BayMan is offline
Old 04-12-2006, 01:09 AM
Timmahh
Banned
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i ve had some luck by just attempting to "BREAK THE BEAD" like you would a normal tire. start by slowly working the tire off the rim edge..and just keep pushing adn working around the rim...in tough cases, i have used a new exacto knife to CAREFULLY trim the glue seal from the tire and rim, take care and use caution so you dont take your thumbs off with the tire. with care you can get the tire off without loosing a digit from your hand, AND have a usable tires to boot.
tim
Timmahh is offline
Old 04-12-2006, 01:19 AM
RCtruckRacer
RCtruckRacer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Boiling is a pain, but it works if you give it time. The last time I did it that way, it took 25 mins per side to get the tires off (MT tires). PITA, for sure. I haven't tried the baking method, but many people have told me it works great: Heat the oven to 375. Once it gets that hot, turn it off, and put the tires in. 15 mins later, they should peel off - CAREFUL! They will be HOT so use oven mits or similar. A new club member works for some kind of supply company for machinists etc and can get acetone cheap. He claims that is the best method - supposedly 5 mins per side. You just put some in a cool whip container and soak one side at a time. Anyone ever try acetone that way?
Boiling is what I have always done, and it always wastes the foams. So it might not be something you want to try with new tires and foams. Especially if you spent extra money on Trinity foams...
RCtruckRacer is offline
Old 04-13-2006, 11:08 AM
Timmahh
Banned
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i have 4 hb tires glues to plastic rims and one is stripped, i was able to get the stripped rim off the tire by the method i explained above, and yes it was a PITA,,, but worked rather well, instead of an exacto, i used a 6in slotted screwdriver and slowly slid it just behind the glue joint and Gently pryed the tire away from the rim. in 2 spots i had to "scrape the tire away" from the rim, but working slow, it was clean and no damage to either tire or rim.. i m gonna do the other 3 today, utilizing a heat gun to see if it will make it any easier. the only prob with useing chemicals is the aftereffects.. they are always there. n usually NEVER good..... i think i may try the oven method on one to check it out. i ve got a nice set of aluminum rims to put with these HB tires..
Timmahh
Timmahh is offline
Old 04-13-2006, 11:13 AM
tadracket
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: BayMan
Has anyone tried thinning the thinner?
tadracket is offline
Old 04-15-2006, 10:04 PM
IamMonsterMan
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thanx everyone, i got the tires off by putting them in the oven for 15 mins. preheated to 325 and had them standing upright.
it actually worked quite well
Old 04-16-2006, 07:10 PM
Henry William French
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
a dremmel tool with a small routing bit works great for grinding bits of rubber stuck in the rim grove.
Henry William French is offline
Old 04-16-2006, 09:04 PM
efretwell
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have tried the acetone method before, and it is mean it attacked the crome of my rims very hard, and it kinda burns. A Better solution is to use "OOPS", it is a cleaning agent used for removing glue and sticky stuff, and it does just that, very well.
efretwell is offline
Old 04-17-2006, 03:33 AM
Sportive.
Sportive.'s Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I use ca-remover
Sportive. is offline
Old 04-17-2006, 08:05 AM
Porsche968
Porsche968's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
IAmMonsterMan: I love your avatar Boo is the best!
Porsche968 is offline
Old 04-25-2006, 10:21 PM
IamMonsterMan
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thanks for the help everyone, and Porsche968, o yeahhhh!!!
