T-maxx Stuck In Neutral!!!!
T-maxx Stuck In Neutral!!!!!!!! (post # 1)
I was drivin my t-maxx the other day when it got out of my range and it took off, it ended up in a field, once i got within range i turned the motor back down to idle ( the truck took off at full speed)... i picked up th truck everything looked ok but when i hit the gas it just revs up, it wont go into gear... so i went home took the whole tranny apart and made sure everything was ok in the tranny, well everything looked fine... so i have no idea why it isnt shifting into forward or reverse... PLEASE GIVE ME ANY INFO YOU HAVE...ILL TRY ANYTHING...THANKS GUYS...
tony
tony
Double posting just makes it hard for you to get an answer. Look at your other post for the answer. CLICK HERE]
