genesis questions
CA
genesis questions
does the genesis 46 come with roto start capability. and does the engine overheat alot. if does please tell me how to avoid it.
thanks
thanks
RE: genesis questions
it has roto start system but it's optional as you said!!
So you will not be able to start it with a roto starter with out the optional roto start backplate.
Sorry for any misunderstanding
CT
yes roto start is opt but its only recomended when the engine is fully broken in, i would say a 3 quarts of fuel. here is a site that will explain all.
http://www.rcuniverse.com/forum/m_38...page_11/tm.htm
you wont be dissapointed if you do get it.
CT
ORIGINAL: michelob78
I just ordered the backplate , I am going to use my Losi starter, I doubt the hex size is the same, that's ok I'll just make my own.
ID
The pullstarter is fine on the genesis, Mine starts within one or two pulls most of the time. Only a few times have I cranked on it for minutes at a time, and that was becuase I was dumb. I would take a pullstart over a roto-start anyday, more reliable, and you can kill the engine if you want to stop for some reason, then start it up immediately again. I love the pull start and I don't find it to be inconvient, infact my genesis is started before my friends savage .28 roto start or my friends electrically started pro 15 maxx, most of the time.
PA
Well I gotta come up with something, I have the backplate but the shaft is completely different from the losi one, The closest thing I have laying around is a t-maxx dogbone. Which brings me to a question is the HPI starter shaft and the Cen one the same thing? I don't seem to be able to find a shaft only from cen just the complete kit.
CT
michelob78 where did you get the back plate from? i can only find the kit for 50.00 with the rotostart. the savage roto def looks the same as the cen's, [sm=idea.gif] i wonder if the k4.6 roto backplate works with it. i'll get back to you[sm=wink.gif].
this is the k4.6 roto backplate, hmmmm, it says that the cen .46 backplate works with a pico.28[sm=eek.gif]
PA
Here is the one I bought.....
[link]http://www.neweramodels.com/cgi-bin/item.cgi?session_id=rngedayolxxntlmkgjjmwumosfhcgr fr&part_id=2385[/link]
I found an Ofna brand shaft that might work, I am wondering if anyone know for sure? I am not worried about the hex end just the end with the ball and pins... if it fits inside cen's backplate?
[link]http://www.neweramodels.com/cgi-bin/item.cgi?session_id=rngedayolxxntlmkgjjmwumosfhcgr fr&part_id=2681[/link]
