Warhead Carb
CA
Warhead Carb
So I got a new carb from hobbyservices, Im kinda lost in how to install it, I tried turning the screw on the motor block right under the carb, which seems to be the release and it wont budge, I dont want to strip it!
Can anyone tell me how to remove this thing?
Is there any kind of sealant or gasket or somthing I should put in between?
Also what glow plug should I be using?
RE: Warhead Carb
after you loosen the nut turn the nut out 5 or 6 turns then lightly tap the bolt in, (the bolt wont come out} then you should be able to twist back and forth the carb untill it pulls out.
