First Hop-Up for a newbie
PA
RE: First Hop-Up for a newbie
Probably a receiver pack....if you mean performance than maybe a good tuned pipe and header. I would drive it for awhile and see where you want the upgrade at, the suspension, speed, durability, or maintenance reduction.
IMO a lot of hop ups are overrated and unneeded. If you really want to get some then use your car and whatever breaks replace it with an upgraded part.
AB, CANADA
First get a failsafe !!!
Come check out the CEN forum for more info on the magnum http://www.rcuniverse.com/forum/forumid_310/tt.htm
IMO, the best hop ups for the magnum are:
New tires like 2.2 masher2000s with foams
Aluminum Brake seat
Metal brake disc
Metal brake plug
Aluminum Brake seat
Metal brake disc
Metal brake plug
I was recently out with my Savage, and it was just seeming sluggish all around. I swapped in a fully charged hump-pack, and it was like a totally different truck - it totally woke up. So, if you don't have one, get a good hump-pack and charge it over night.. A tuned pipe might give you a performance/speed boost as well...
Absolutely, the first thing you need is a failsafe. Then you need a hump pack. After that, start upgrading the performance parts. Dustin has a good list in his post.
