RC Monster Trucks Discuss rc monster trucks in this forum
new question about my shocks
Old 10-07-2006, 01:21 AM
motox28
Default new question about my shocks
hey i have the tnx and i was wondering if it is bad to run 1 shock out of 2 on the back of my truck with only a litle shock fluid...-
Old 10-07-2006, 11:29 AM
Rc EnthuSiasTs
Rc EnthuSiasTs's Avatar
Default RE: new question about my shocks
if your truck is not bottoming out and handles good, i dont see why not. But it will be hard on that one shock.
Old 10-07-2006, 12:40 PM
motox28
ya on the back only i put 1 shock with a little oil and the other 70 im just trying it, its kinda coppying the new pro line where one is to shlow it down for going up and the other is for puching the car up....so idk i think that it micht be ok as long as i have some fluid in the one to keep it lubricated thanks
Old 10-08-2006, 11:05 AM
jnev
that's not gonna work at ALL like proline's progressive setup...
Old 10-08-2006, 11:54 AM
motox28
idk well it seems to work hella good i was just wondering if it bad for the shalk but it works good because my car was like not going back up all the way like after i puch it down so i took out the oil in one so it had less resistance and put 70 in the other so it had more resistance so it wouldnt bottom out..
how do pro line shalks work...
Old 10-08-2006, 11:02 PM
RCtruckRacer
RCtruckRacer's Avatar
You want the shock to be full with oil. If you fill it up correctly, it will rebound about halfway when the shaft is pushed in with the spring is off. Thinner shock oil allows faster movement of the shaft up and down, thicker oil slows the reaction. Adjusting the preload changes the ride height- so that it won't sit too low after taking a jump. Hope that helps!
Old 10-12-2006, 05:13 PM
Rc EnthuSiasTs
yeah, if it was not coming back all the way, adjust the preload spacers.
