Proline 17mm to 23mm hub extenders
FL
I am running the proline 17 to 23mm hub extenders with 40 series rims
the stock pin that holds the regular hub to the axle and that is held in by the wheel hex has no wheel hex to hold it in when you have this set up? i tried some thread sealer on the pins but when i am running at full speed they work themselves out? anybody ever used these and have a better solution?
I tried a ss screw with nylock but it introduces some wiggle as its not the exact size. there has to be a better way?
RE: Proline 17mm to 23mm hub extenders
go to neweramodels.com and they have extensions for 23mm type wheels. I actually bought some for a revo and they work. I know they have some for the savage,t-maxx and revo.
