Rc Trucks In Mud How Do I Clean The Engine..........
HEY GUYS I JUST GOT BACK FROM DRIVING MY TRUCK AND I WAS WOUNDERING WHEN YOUR ENGINE GETS ALL MUDDY AND YOU SEE LIKE OIL AND FUEL BUILD UP WHATS THE BEST WAY TO CLEAN THE WHOLE ENGINE
HEY THAT SOUNDS LIKE IT WORKS WELL
BUT I KNOW THERE HAS TO BE SOMTHING OUT THERE YOU YA KNOW WHAT I MEAN LIKE IF I TOOK OFF MY CLUTCH GLOW PLUG AND PULL START AND JUST DROP IT IN SOME TYPE OF LIQUID I DONT KNOW BUT THERE HAS TO BE SOMTHING THAT WOULD WORK
YES THAT IS WHAT IAM TALKING ABOUT HOW TO CLEAN THE OUTSIDE OF THE ENGINE CLEAN
NO THE INSIDE
NO THE INSIDE
CA
Has anyone here had any trouble with nitro rusting your engine. The LHS guy told me it would and sold me some after run stuff that suposedly keeps it from doing that. Also I think I might have gotten a few specs of sand in my air intake, is that really bad?
My Feedback: (38)
If you leave it in there for a while yes it will rust, the model fuel attracts moisture which is bad.
Ideally when you done running pinch off the fuel line or pull it off so it runs dry, then put some after run oil in it and crank it over a bit and your good to go. I never have done this and have never had a problem FWIW.
Hey I just read this in the BB manual. HPI sells something called HPI Nitro Cleaner. Maybe you can use this to clean your engine. Thought anyone?
http://www.hpiracing.com/index2.htm
