mgt pipe question
mgt pipe question
I have a os 2050 pipe I wantd to try on my mgt. My question is I always thought that it was made for a .21 motor will running it on a .28 motor mess anything up. I don't think it will but it never herts to ask. Anyone else run this pipe on there mgt?
OR
RE: mgt pipe question
Not sure about that pipe... The most common pipe I've seen people run are the XTM Mammoth pipe and LST or LST2 pipes.. they are all cheap and perform good if that one doesn't work out for ya'...
FL
That pipe will work fine. It's shown to be used with a .21 VZ-B V-spec, which probably puts out more power than the stock .28 anyways. Do you have the header for that pipe or are you using a different one? Just wondering because it may not work too well with the stock MGT header since it is a 1-piece design.
Yea I have the header for it. I'm gonna try it when I get home in the morning. I think it might fit with out too much trouble. I was useing it on a chrono p5 in my hyper 7 but I haven't messed with it much since I got my mgt.
