Hey T-Maxx Guys... HELP!!!
does anyone know why my maxx sometimes dosent want to go into or come out of reverse??? anyone have this problem? is there a remedy??? thanks guys. troy.
WA
Make sure that your linkage is tight (the stop at the end of the spring) on the FWD/RVS servo is tight, I had to make an adjustment there because of the same thing. Worked great after that..
my stock t maxx did the same thing the idle was just a hair to fast also if you try to shift the tranny before the rpms bottom out it gets stuck between gears
I moved the clamps on both sides of the springs in about a 1/4 of an inch. Don't make it too tight or your servo will bind up. Just make small adjustments and try it until you get it where you want it. I adjusted mine and it works a lot better.
ONCE YOU GET THE PROPER SET UP WITH THE SPRING MEASURE IT AND CUT A PIECE OF FUEL TUBING THE SAME LENGTH AND REPLACE THE SPRING WITH IT, THIS MINIMIZES THE CHANCE OF HEAT DISTORTING YOUR SPRING AND THE FUEL TUBING WILL STAND UP BETTER PLUS GIVE YOU BETTER CONTROL OF THE STE UP
