MGT wont shift gears
I was out bashing earlier today and I noticed when I took it on this big parking lot for some fast driving that it wasn't shifting in to 2nd gear. Anyone know what might be causing this? I already tried the shift screw and changing it had no effect.
1 Post
RE: MGT wont shift gears
The shifter hub may have come loose on the shaft - red threadlock or using two grub screws instead of one will solve that problem. If that's not it then something in the transmission may be damaged or binding.
I will have to pull th tranny tomorrow night, I need to get to bed I hae school in the morning.. thanks for the tips guys
MI
ORIGINAL: OneMoreSuicide
Yeah, I saw that there was 2 screws. I was turning the one thats at an angle with the spring and small ball bearing. I checked and there was no stripping and I found no burrs i will have to check my rpms then when I can drive it next which will prolly be tomorrow after school.
