Tmaxx problem
Tmaxx problem
I just got my Tmaxx broken in and now when I crank it up my radio doesn't seem to work. If I stop the engine then the radio works fine. Could someone please give me a clue with this thing?
Tmaxx problem
WEAK BATTERIES ,OR DID YOU SHORTEN THE RECEIVER ANTENNA,OR DID YOU CHECK FOR SPORATIC FEQ'S ......BY THIS I MEAN YOU CAN CONTACT YOUR LOCAL TV/CABLE REPAIRMAN TO COME TO YOUR PLACE AND CHECK FOR FREQ'S THAT ARE FROM ............LETS SAY METAL FENCES,ALUMINUM WINDOW FRAMES,GUY WIRES,CELL PHONE TOWERS......YOU'D BE AMAZED AS TO WHAT CAN INDUCE RADIO CHATTER..........IF THAT DOESN'T HELP TRY A DIFFERENT FREQ,.........OR ANOTHER THING MAKE SURE YOUR ANTENNA IS PROPERLY SCREWED INTO YOUR TRANSMITTER BY TURNING CLOCKWISE...........IF IT SPINS FREELY YOU MAY NEED TO HAVE IT SERVICED
