Installed OFNA clutch shoes on MGT. WOW!
GA
OFNA racing shoes 1.8g
A very inexpensive and simple hop-up part that makes so much of a difference.
After installing these shoes, the throttle response is amazing. I really thought there would be a little lag as the gold 1.1 springs held the shoes back but when I hit the throttle there was instantaneous response and it actually spun all 4 tires on the pavement.
Stock motor, stock gears, FOC, Infinate wheelies on demand now!
Im satisfied with this upgrade and would recommend them to any MGT owner.
FL
RE: Installed OFNA clutch shoes on MGT. WOW!
Let us know how they hold out for ya. I was thinking about getting some aluminum shoes, but I figured it might be harder on the drivetrain.
OR
I'm running the same set, they are great so far - part #10011.... there's also a silver set, which are 1.7, they are a little more expensive but the are harder aluminum and should last longer - part #10010
OR
No problem..
comerford... I have the Werks but it's been sitting in my parts bin since the 1st week I got it - the adjusting nut would constantly tighten up on it's own, eventually keeping it from engaging.. It was killer while it was set right.... Some guys have good luck with it, I didn't..
GA
your right, they are definately harder on the drivetrain. Since they let the engine rev a little higher before engaging, its like dumping the clutch in a car. If I keep everything tight in the drivetrain, it should last.
ORIGINAL: Bria1
PA
can you run a centax type clutch in the mt? I was reading about the centax clutch and it was saying about how well you can adjust them for fast or slow engaugement.
