Recommended Nitro Fuel
What do you guys (overall) think is the best fuel? My LHS stocks O Donnel, Trinity Monster Horsepower, and Wildcat (their 2 & 4 Cycle type) fuel. So basically, I have to choose between the 3. I'm looking for 20%, and this is going to be used in a Axial .28.
Also, sorry if this is in the wrong section.
Thanks for the input!
RE: Recommended Nitro Fuel
I've heard some bad things about O'Donnell R2R fuel, but do you think the Racing Fuel will do good? A lot of fuels have more than 12% of oil so I don't know which to go with.
saying an engine needs a certain amount of oil in complete bs, it depends a lot on the quality of the oil, if you went to the doctor and said, 'i wanna live till i'm 90' and he told you "eat 2 pounds of food every day, doesn't matter weather thats salad or deep fried chicken as long as you eat 2 pounds a day" you'd be running out of there fast, if i remember correctly O'Donnell use 100% caster oil (please correct me if i'm wrong here), and they use good quality stuff, thats how they get so low oil content in there fuel, a lot of fuels use synthetic oil because it's cheaper but it's also not as good at high temperates as caster oil (caster oil doesn't actually burn until 800 degrees F) so they need to use more oil.
I use Sidewinder %25 with %14 oil content.. Some people say that's too high, but I think that's only theory. I've run Tornado, Jet, and now Sidewinder, which I've run in four trucks - and I've been very very happy with it. However, of the three trucks I'm currently running, none has two gallons through it yet(well, the Lightning GT had maybe a gallon of JET through first, and since then maybe 3/4 gallon of Sidewinder, and the improvement with the Sidewinder is noticeable....)
My trucks seem to start well, idle well, tune well, and have good consistent performance(I also run OS A5's in all of them..) The only factor I can't attest to yet is longevity...
So I don't know. I'm starting to think fuel choice and opinions on it are just all over the place, so all I can say is what works well for me - so far - and that's Sidewinder with %14 oil. Period.
You also absolutely cannot trust your LHS on this - moreso than with any other RC product I find.. One guy will say fuel X is the worst junk there is, the next guy that it's the best... All total BS...
I only bash, BTW.. I guess racers want something different....
1 Post
ORIGINAL: ttoks
believe me, quality makes a difference, lower quality oil will break down at a lower temp or inconstantly when compared to high quality stuff (synthetic isn't the best with high temps no matter how good the quality is), i prefer to run fuel that has 100% high quality caster oil and no synthetic oil at all (this is what my hobby shop mixes, they use 14% with 20% nitro), i'v had a go at mixing my own fuel, but it's just easier to buy it from the hobby shop.
also the amount of oil in fuel depends on how much nitro (with more nitro you use more fuel through the engine, so you need less oil in the fuel) and the size of the engine, surface area in the engine only go's up by 51% to the displacement so you need less oil in the fuel there as well, while a smaller engines need more oil.
O'Donnell is high quality fuel, i'v never used it because it's just about impossible to get anything fuel shipped here from the U.S but you hardly ever hear complaints about it.
also just as a side note, the less oil there is in your fuel, there more methanol there is, so the more power you can get out of a given amount of nitro.
