Titan Pic Nakid!
NJ
Titan Pic Nakid!
Ok caseyddr hers you pic. we took the titan out to day for a little run around the parking lot. and Be for the tank was even empty it was on the banch again the stock airtronics blazer just did not feel rite. so we pulled it out, and installed the Lynx3d with Spectra and Novak Xxtra recever and a 2000mah metal hydride battey pack the servos seem ok for now we will try it this way for now...
Titan Pic Nakid!
Where did you get that battery pack and how much was it?!
I'm usin a 650mA just to reduce load. I had a pack of 1800s at 4.8 volts and that thing would run for a week lol so I decided to cut down on weight and size
ram
ram
NJ
Titan Pic Nakid!
Yes bad those aer the stock tires and wheels.Buggies you can get Metal Hydride battery backs in aney size and MAH. range from 300-3000. thease packs are olny half the wate of nicds and will last 2-3 times longer. but REMBER no fast charging! 100-125mA max.. the time you get from a charge mor than makes up for the long charge time and you can charge your truck every night these cells are not subject to memery bild up like nicd,s O yes bad as for the chassis the hole truck is stock out the box as you see it with the excepthion of the of the recever and battery pack.
