ideas for a small block for my TNX????
hey everyone, recently my Tamiya TNX had a little engine trouble. it wont shift, and its squirting green goo over the cooling head??
its an O.S. 18, which is an awesome engine but im lookin for something else so its not just sitting here....
anyone know of a small block that would power this monster??
thanks
-James
thanks
-James
FL
RE: ideas for a small block for my TNX????
The [link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXHLV9&P=ML]OS .18TZ[/link] is only 140 at Tower right now. That's only 30 more than the cvrx and has a lot more power. How much are you looking to spend?
well i wouldnt mind goin big block, but dont know where to get the right big block conversion.... but, for a small block, between 90-130....
FL
For big block conversion you could either use [link=http://www.neweramodels.com/item.cgi?session_id=lybnwrfaitqebhnbripwjyxpblgyji sl&part_id=2182]this[/link], or get a chassis and parts from a TNX 5.2 off ebay.
For a small block in that price range, your best bet is the [link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXGGP6&P=ML]OS .18cvrx[/link].
RI
The OS .18cvrx is a excellent engine for the TNX and is side exhaust wich means it will drop right in without any modification. A engine with rear exuast will require some modification to the shock tower for the exhaust manifold to fit.
My Feedback: (23)
WI
ORIGINAL: jvs8864
RI
The tz will not work without modification because it is rear exhaust.I have TNX 3.0 and it need a side exhaust engine. The big block conversion is available at www.neweramodels.com
FL
ARENT OS??? not any that are small block. OS makes the best small blocks for MTs. Why don't you want an OS?
ORIGINAL: jvs8864
lol all good suggestions. but any that ARENT O.S engines????
thanks
-James
thanks
-James
RI
ORIGINAL: jvs8864
mostly expense and the break in.... i really just wanted to try suttin new
i guess i dont have a choice
MA
For ease and simplicity I'd ge the ,18CV-rx. If you're up to doin some special mods, and a little custome work then go with the Tz...I've won races with both.
But the Tz doesnt have much competition on the straights, including big blocks.
