RC Monster Trucks Discuss rc monster trucks in this forum
need help
Old 03-09-2003, 11:20 PM
Alteramod
Alteramod's Avatar
Default need help
Ok, here is my problem. When I start to give my buggy some gas it is fine till about 1/4 throttle then the wheels will trun left then back strait. It will keep doing this on and off till I give it more gas. When I go past about 1/4 throttle I can here my engine slowly reving up so I let go of the throttle and it still will rev up for about 10 seconds. And while it is doing that my wheels will stay turning left.
I turn off the engine and play with it and it works no inerference till I start it up and it will just do what ever it wants past 1/4 throttle.
IDK what is wrong please help.
Old 03-10-2003, 12:05 AM
3maxxman
Default need help
Replace your batteries, check for metal to metal contact (like exhaust pipe on chassis) , check the RX wire for nicks and making contact with the chassis, Change your crystal to another ( make sure it's not the crystals) Try another radio.
Good Luck, please post when you figure it out.
Old 03-12-2003, 04:03 PM
Alteramod
Alteramod's Avatar
Default need help
Hey, thanks for the information. I will check it over tonight after I get home and do what you said. Then I will take it out and see if it works. Ill tell you if it does or doesnt.
Old 03-13-2003, 02:29 AM
Groundforce-RCU
My Feedback: (20)
Default need help
You definitly have some torque issues. Could be a weak servo saver ( if you have one) , or flexing somewhere in the steering.
