I keep going through glow plugs
My Feedback: (34)
RE: I keep going through glow plugs
Is this what I need? It's a head gasket for my engine. http://www2.towerhobbies.com/cgi-bin...&I=LXGZB0&P=OW If not, how do I know which shims will work with my engine?
FL
I'd get this - http://www2.towerhobbies.com/cgi-bin...?&I=LXGMM9&P=Z
It comes with 2 different thicknesses. I'd start by adding the thinest one. But check out what happened with it seizing up first before putting more money into that engine.
My Feedback: (34)
Well this is nice, took the engine out and tried removing the 4 screws in the head and 3 outta the 4 stripped out. This engine is pretty much junk now, burning plugs, leaking from the rear bushing, 3 stripped screws, needs head shims and doesnt run like it used to even with a 1 gollon old piston/sleeve. I would love to just get an os but I dont have that money after dropping over 200 into one of my other projects.
My Feedback: (34)
Took it apart after hacking/drilling the screws out and the piston/sleeve are junk. A piece of coil from one of the blow glowplugs frll into the engine and got caught in between the piston/sleeve. I dont have the money for something like this so I might must convert it to electric for a while if I can find a usable pinion.
#31
CA
ORIGINAL: CustomTamiyas4Life
#32
My Feedback: (34)
Actually, no. closer inspection revealed that the spring clip holding in the pin going through the piston had fallen out and that was the wire that got jammed.
