savage transmission
My Feedback: (9)
savage transmission
No, it's designed to be dry.
If you put heavy lube in there, the centrifugal force activated 2-speed won't work.
I took mine apart to install reverse module, and the gears were slightly rusted. I did spray WD-40 in there to help dissolve the rust. I removed most of it while removing rust, but some always remains. Hasn't hurt the tranny any that I can tell.
