warhead evo racer
warhead evo racer
does anyone have this truck in full race trim with a bumpstart motor. I would like to see this truck setup for the track or is this thing a lost hope.
TX
RE: warhead evo racer
ORIGINAL: 2DMaxLST!!
Has anyone put a high end bump start engine in one?? Can it use a standard one piece header, like a truggy?? If you have put a high end bump start engine does the drive train handle it?? Does anyone race one?? What does it weigh setup for the track.
I have bin trying to build up the courage to take on one as a project. deffenety used for cheep but cant seem to get any straight answers. Theres 400 plus pages of threads and i only here of one person trying to make it into a racer.
NE
I have one as a project also but I have gotten most of my help from bbmods like it said earlier.
Check out his gallery.
I dont know about the bump start?
GA
I have an original Warhead and I used a bump start on it. Got the bump start because I was tired of killing my fingers and braking pull starts on the super pooper before I put the Axial .32 in it. still use the bump box.. even though the axial fires up imediately ....lazeyness I gess.
can some one list the main weak points on this warhead evo and is there a forward only for it.
I also want to know what size wheel hexes this truck comes with, or does it have buggy style axles to accept 17mm or 23mm adapters.
I have a mugen mbx5t with a hot mod nova 28 on it wich i will be replacing with a .21 because its over kill. I would like to put the nova 28 in the warhead whats the strongest motors you have seen in this truck.
CA
ORIGINAL: blackrain
I ran nova top p5 .21, o.s. rg .21, and a hyper.21 8 port and the main problem I had with the truck was the tranny. After I added the foc shaft it didn't bother me again!
I raced the truck 5 times it does handle really well, and if you get it dialed it will rock!
CA
Were you able to use standard headers with those engines??
http://www.nitrohouse.com/images/Mugen/mr14006.jpg
you might have to shave a little from the tvp.
