RC Monster Trucks Discuss rc monster trucks in this forum
Engine Question
Old 10-08-2007, 06:01 PM
think20
think20's Avatar
Default Engine Question
When I first start my MGT engine it works fine for a minute or so but then my MGT sounds like its in a high rev and even when I let go of the throttle it keeps moving quickly and loudly (all the linkages have been checked and are fine including the idle adjustment). When I hit the brakes the truck does come to a stop but the engine's reving continues. Is my clutch not disengaging or is there another explanation for this problem?
Old 10-08-2007, 07:13 PM
binaryterror
binaryterror's Avatar
Default RE: Engine Question
Sounds like tuning...check the low speed might be lean...
could also be the idle.
Old 10-08-2007, 09:12 PM
think20
think20's Avatar
At first thats what I thought but its not the idle or mixture I have already tried different settings
Old 10-08-2007, 10:11 PM
Bria1
It sounds like it is too lean if your linkages and idle screw are set properly. If you have richened it up with no change, you probably have an air leak.
Old 10-09-2007, 05:27 AM
SAVAGEJIM
SAVAGEJIM's Avatar
ORIGINAL: think20
Is thsi the stock MGT engine or is this an afterm,arket engine? If it is an aftermarket engine, which one is it? The reason why I ask is beacuse some engines have bad carbs on them and no matter how much RTV you thow at them or how good your tuuning skills are, these engines will leak massive amounts of air and always run away.
Aside from that, try attacking all possible air leaks (replace all lines, the tank, RTV seal the engine, etc.).
Old 10-09-2007, 08:21 AM
think20
think20's Avatar
It is the stock MGT engine
