Turbo Plugs?
Turbo Plugs?
What do you guys think of turbo plugs? Do any of you use them in your Savage? If so, is there a noticeable increase in performance? Thanks.
1 Post
Turbo Plugs?
You can only use turbo plugs in engines designed specifically for them. They will not work in the engine that comes with the savage.
Oversimplification:
Turbo plugs are like regular plugs but have a taper on the bottom of them. So does the engine head (or button). When the plug is tightened, the bottom of the plug is flush with the combustion chamber.
Oversimplification:
