Overall thoughts on warhead evo?
OH
RE: Overall thoughts on warhead evo?
You really can't beat $329! Unfortunately I paid more for my original Warhead. Oh well, I've gotten my enjoyment out of it. Best of luck to you.
GA
ORIGINAL: jombo
dont do it, search around there are other trucks probably more durable and user frendly than a warhead.
ORIGINAL: jombo
GA
ORIGINAL: Duratraxman1
I dont know if its just my truck, but its almost as easy as electric. It is so much better than my Aftershock.
ORIGINAL: jombo
You have got to be joking, man
ORIGINAL: IL2mSturmovik
ORIGINAL: jombo
GA
No. Im not. I absolutely love this truck. Im sure there are PLENTY of trucks that would easily beat this truck in a race, but for me to go out, start it and go, it is the best. It has plenty of power and top speed. The only thing i dont like about it is that it is very hard to work on. (not that i do alot of it)
ORIGINAL: jombo
Thats awesome you are digging your Warhead, I have just read there are so many issues with it on here. I was considering it for a time until I read teh Warhead thread on here[]
PA
My warhead is fast handles great and is plenty durable. Biggest problem I had was the original spur gears. I have a steal one and it is great. I put an Axial 32 in and it has tons of power maybe even to much. Super Tiger engine had plenty of power, but it was hard to keep it tuned.
CT
I think this is a great truck you just have to get to know it, taking it apart is a pain the first time but once you figure out what order to takes things off its a breeze. Even with the problems i've had I still love it because something goes wrong you just call duratrax and they replace it for free if its not your fault. I've only had a few problems with the truck but im sure its do to me not going over it before using. The first problem was the topshaft gear had the pin break on it into three pieces. The last problem was the CV joints dogbones were wearing fast, and it blew a pin in the lower joint, but after a talk with a technician at duratrax they told me that it was because my truck was set up in rumble mode. They said that the angle that the CV joints were at that there was too much added stress on the trucks CV joint components and that they will always abnormally wear unless you keep the truck at factory settings. This is a fast truck although it wont do wheelies, it is made for racing, it has excellent handling and after some hop ups this truck is really insanly fast. I have Aluminum transmission cases front and back, aluminum bulkheads front and back, aluminum clutch shoes, aluminum steering bellcrank, aluminum draglink, ultralight clutch bell, and reverse eliminator, and i removed the shifting servo. I also noticed that the aluminum steering bellcrank and draglink produce a much better handling truck. JM2C and i hope that i helped save anyone from any unneeded aggrivation.
