T-maxx chassis questions
TX
I bought a T-maxx here on RCU, but it seems to be the older one, but, it also looks like the 2.5 chassis, are they the same, does anyone have pics of the old T-maxx chassis?
thanks
thanks
TX
so then why cant the new 2.5 fit on the old chassis? ,i have a OS .15 CV on mine, that little engine dosnt want to run, does anyone know the setitng for it, like where they should be sett when it comes out of a box, OS plane engiens are set at 2 1/2 turns, is the car engines the same?
Alot of the new 2.5 parts replaced the old ones.
The new 2.5 chassis is 3.2mm thick.
the old .15 chassis is 2.5mm thick.
I'm runnin the old chassis w/ aluminum braces so it's stiff enough.
Check to see if it has bulkhead braces.
If it doesn't it's 1st generation T-Maxx.
sure the new 2.5 will fit you just need the kit which comes with new linkages and new header and pipe ... and os 15 cvx is 2 turns so 2 1/2 to be safe
then if its a 10e carb the lsh 1/2 turn out from seated ... head over to os engines web site they got the engine manual for ya
The 2.5 engine will fit the old Maxx.
That was a bogus post.Dude didn't know what he was talking about.
You may need to get a 2.5 conversion kit,but it will definetly fit.
The 2.5 IS a .15 sized motor.
The label it 2.5 cuz thats the displacement.
TX
At the moment i have a OS .15cv on it, but can you tell the difference in the 2 chassis but looking? thansk for the info guys. i think ill keep my O.S. .15cv and not worry about the 2.5, i like OS more
thansk again, keep the info coming for i am new to the R/C car/truck world and would like to learn more, so please put info in, o yes,
bulk head brace, can you expalin it more clearly, like explain what it is ill be looking for, and
I think its the older for i have the older Traxxas .15
NJ
bulkhead braces and chassis
the chassis are not the same the2.5 is alot harder to bend andthe bulkhead braces are what hold the bulheads together for extra support so my advice is to get the 2.5 ones cause they r cheap and very strong jus get aftermarket screws
makin traxx on your azz
