Picco 26 BIG BLOCK carb STUCK
Ok so i removed the screw that allows the carb to come off on my picco 26 BB. The carb is STUCK. no matter how hard i pull or tap at it with a hammer it wont budge. what should i do?
RE: Picco 26 BIG BLOCK carb STUCK
haha bigger hammer, i like that one. But ive tried twisting it and it wont even budge. Ill continue to try and twist it and put the hair dryer to it.
My Feedback: (33)
ORIGINAL: -SomeGuy-
Remove the two halves of the pinch bolt and it should come out very easily.
Can't remember what type of pinch bolt the 26 uses but if its the two half one then you need to lossen the bolt slighty and then give it a sharp tap to free the other half, the carb should come free then, sometimes if the bolt has been tightened for a long time half the clamp part gets seized in the case and will not allow the carb to come loose.
QC, CANADA
All piccos use 2 piece pinch bolts. And whenever i need to remove my carb i completely remove the bolts, never had any damage caused, dont see why it would.
ORIGINAL: narn
Whatever you do, dont try to force the pinch bolt all the way out - is destroys the carb neck. [:'(]
