..:: Voided Warranty- OFFICIAL Home Made, Modified, and Custom Parts::..
Post all of your home made, modified, and custom parts here! Please include a picture(s), and a discription of what it is you made. If it saves weight, post how much weight you saved. So post up people!
RE: ..:: Voided Warranty- OFFICIAL Home Made, Modified, and Custom Parts::..
I will start off-
Modded parts-
Shaved every other nub off of the stock Maxx tires. ( sorry no pic, the camera isnt working).
Drive shaft durability mod, where I took and extra piece of male half shaft, and put it on the exposed female half shaft, to help prevent twisting.
Custom made parts-
Custom built rear A-Arm guards, made steel sheet metal.
Custom built full center skid plate, made from steel sheet metal.
Custom built front aluminum bumper, made from 1/4'' aluminum rod stock.
Modded parts-
Custom made parts-
CA
I got a mod costum made my lst2 pipe to fit on my mgt.
FYI i dont use the header no more.
ORIGINAL: Snaut Rocket
Just made some dual rate springs using some old copper colored/ extra firm Monster GT springs, some wire cutters, and a pair of vice grips. Here are some pictures--
CT
made some shocks fit my thunder tiger st1 and a few extra parts for a second servo for it
ORIGINAL: jombo
i would love to do that to my mgt.
CA
go to monster gt .com and check out the lst2 shock mod there. Its not that easy compared to theres.
CA
here you go they stop building it
after 8 pages.
http://www.ultimaterc.com/forums/showthread.php?t=80496
after 8 pages.
after 8 pages.
after 8 pages.
CT
actually there not muggy shocks their smaller lol. these are after shock shocks , i cut the cyclinder and the piston to fit the st1 here are the cut parts i call it chop cut rebuild lol. by traxxas standards (when they come out with a new engine they say its 60 or 50 %more hp)these shocks are 35% longer (6mm lol) than stock and more oil to boot.
CT
CA
did you read the link i posted. theres alot of work involved in getting them to work. (properly)
CT
what there trying to do is make a mount that goes between the 2 shock positions ,thats the part that is causing problems. this shock that i cut will fit (well maybe) in one shock position . the lst2 shock tower is a almost a direct fit for the mgt i will post some pics of mine with it, the lst2 or the aftershock shocks are too long to fit but if you cut them like i did with the st1 they should fit
mugen mbx5t gas tank mgx5t wing and mount losi 8t wheels and a .28 motor on a cen nemesis
ORIGINAL: blackrain
Just curious, but why the .28 in that truck? .46 have too much power?
CA
from the looks of it he probably wanted to race it.
i dont see that .46 holding up very well on the track.
