MegaTech M16
MegaTech M16
I have my TMaxx comming in soon. It's comming with a MegaTech M16 motor in it. Does anyone know if it's a good motor or not? Will it be worth it to make it an EZ Start or should i just keep it as a pull start? Also, will changing the cooling head make a difference? Are there any brands in particular that'll work for this engine?
MegaTech M16
Pull starts are a royal pain in the *****, but I don't how difficult it would be to make the Megatech compatable with the easy start system. You may not have a choice.
MegaTech M16
You can adapt your ezstart to the m16.
http://pages.sbcglobal.net/acardenas/Modifications.htm
Just leave the pullstart on until it breaks.
It will break.
If you don't know how to fix it,or don't want to spend$20 for a new one,then put the ezstart on.
My pullstart has broke like 4 or 5 times and I have less than a gallon thru it.
It will break.
